It is currently Mon Jul 21, 2025 12:31 am
PostPosted: Sat Jul 21, 2007 9:58 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I cannot find the post re: the above.
I would like to know what wood used for top and how is it braced-I'm thinking light.
PostPosted: Sun Jul 22, 2007 12:18 am
Here is the info for a Martin D18V I think you will learn all you need to know here Bob.
   Let me know if you need more info
john
http://www.mguitar.com/guitars/choosing/guitars.php?p=m&m=D- 18V
PostPosted: Sun Jul 22, 2007 1:11 am
Fixed link
PostPosted: Sun Jul 22, 2007 2:32 am
Bob are you thinking to make it to make it "fingerstyle" do you make the nut wider 1 7/8"?
PostPosted: Mon Jul 23, 2007 12:59 am
Last Name: Johnson
State: CO.
yes, I l plan awider fingerboard 1 13/16. What is the best wood for top. Is bracing diff. because less force transfered to soundboard and therefore vibation should be increased to ge top moving?
PostPosted: Mon Jul 23, 2007 10:08 pm
Last Name: Johnson
State: CO.
Bump
PostPosted: Mon Jul 23, 2007 10:13 pm
Last Name: Johnson
State: CO.
Thanks all. Pat what I am most cusrious about is:
Fingerpickertops, I have read are either thinned or different specie--WRC, REDwood. The reason being that the top must be made to vibrate with less force applied to the strings. What top do you use, approx how thin, what wood and size of bracing?
Thanks, Ihope my question is clean.
PostPosted: Thu Jul 26, 2007 3:39 am
Last Name: Johnson
State: CO.
bump
